Engine shuts off while driving?
130,000 MILES • 1.2L • 4 CYL • MANUAL
RALPH JOHNSON
I recently replaced cam sensor and crank sensor based on computer readings, first crank sensor failed to start, second worked perfectly for a week or so then failed. Truck would start and worked fine for a day or so, then failed again. Also, the left-hand rear turn signal is not working. I replaced bulbs, but flasher still not flashing.
Mar 7, 2023 at 4:02 AM
  • 110,248 POSTS
When it stalls, does it restart right away, or do you have to wait? Also, when it won't restart, have you checked to see if there are both fuel and ignition spark to the plugs?
Do this. See if the engine will start if you use starting fluid. If it does and then stalls, we have a fuel-related issue. If there is no change, then it's likely ignition related. In this case, I need you to check for spark at the plugs.
Here is a link that explains how it's done.:
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
Let me know what you find. Also, I have a favor to ask. Could you repost your second question? We try to keep the threads specific to one topic, so they are more helpful to others. I hope you understand.
Here is a link to start a new post:
Just copy and paste the turn signal issue to the new post. Again, I hope you understand.
Mar 7, 2023 at 11:08 AM
