1998 Chevy S-10 engine stalling on freeway for a few second
WOOOODY
  • 1998 CHEVROLET S-10
  • 6 CYL
  • 145,000 MILES
Hello!
My chevy s10 runs great untill it warms up, then on the freeway it will stall for a second or 2. Come back to life and run great. When I get of at the exit I need, at a stop light it will seem to be running at a low idle then stall. Restarting just fine, then it will continue doing this until I get home. I can hear the fuel pump running before and after the restart.
I changed the fuel filter, egr valve, air filter, and coil.
No codes found at autozone.
I was wondering if it could be the fuel pressure regulator or looking for ideas.
Thanks
woody
Thursday, February 28th, 2008 AT 11:58 AM
MASTERTECHTIM
  • 4,750 POSTS
I would be more apt to suspect fuel pump. I would check the pressure. Also there is a test you can run on it with a amp meter. The fuel pump connectors are notorious for loose connections and melting, id start there
Thursday, February 28th, 2008 AT 12:06 PM
