eng misfiring while driving and very bad at idle
138,000 MILES
JOSHUARMILLER
van idles very bad fixed numerous vaccum leaks cleaned mass air flow sensor fuel pressure at 70 psi. there are no codes except for a post cat code on bank 2 for heater circuit. can't get scanner to give me mode six data. tried unplugging coils to look for a "no change condition". looking for a place to start testing but don't know where to start any ideas
Aug 25, 2013 at 6:12 AM
KHLOW2008
  • 41,812 POSTS
Were the spark plugs checked?
Aug 26, 2013 at 4:07 AM
JOSHUARMILLER
They were replaced with the fuel injectors
Aug 26, 2013 at 4:29 AM
JOSHUARMILLER
Plugs are soaked in fuel
Aug 26, 2013 at 4:31 AM
KHLOW2008
  • 41,812 POSTS
Plugs are soaled in fuel indicates excessive fuel is getting to the cylinders and it could be a fault with the pressure regulator or engine coolant temperature sensor.
Use the casn tool to monitor the ECT to see if it is working correctly.
Aug 26, 2013 at 4:37 AM
JOSHUARMILLER
Will do thanks
Aug 26, 2013 at 4:39 AM
KHLOW2008
  • 41,812 POSTS
Any update on this?
Sep 14, 2013 at 2:35 PM
