Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Mitsubishi
Eclipse
Engine
Symptoms
Locked Up
engine locked
1995 MITSUBISHI ECLIPSE
165,000 MILES • 2.0L • 4 CYL • FWD • MANUAL
ANTHONY GRAINGER
MEMBER
Replaced timing belt put crank pulley top dead center top back pulley three o'clock front pulley nine o'clock and now engine will not turn.
Sep 12, 2016 at 1:21 PM
SATURNTECH9
Experienced Mechanic
So are all the timing marks lined up and timing belt is on?
Sep 12, 2016 at 1:32 PM
ANTHONY GRAINGER
MEMBER
Yes, turned switch motor wont turn. when I was lining up marks problem must of happened.
Sep 12, 2016 at 1:37 PM
SATURNTECH9
So did you only turn it over by hand or did you use the starter? Also did you replace the radiator belt for maintenance or did the belt break?
Sep 12, 2016 at 1:39 PM
ANTHONY GRAINGER
MEMBER
Yes turned switch wont turn when I was lining up marks problem must of happened.
Sep 12, 2016 at 1:40 PM
ANTHONY GRAINGER
MEMBER
Sons water pump motor went bad broke timing belt when it did. trying to get him going replaced water pump and belt.
Sep 12, 2016 at 1:43 PM
ANTHONY GRAINGER
MEMBER
Used hand and tried starter wont turn motor.
Sep 12, 2016 at 1:44 PM
SATURNTECH9
Could have bent a valve from breaking the belt not uncommon. Auto zone rents inspection cameras you could use one to check the valves.
Sep 12, 2016 at 1:47 PM
ANTHONY GRAINGER
MEMBER
Needs some. Hints on what to try next?
SATURNTECH9
Take the timing belt off turn the crank 90 degrees counter clockwise then see if the cams will spin?
Sep 12, 2016 at 1:50 PM
ANTHONY GRAINGER
MEMBER
What do you suggest I do next?
Sep 12, 2016 at 1:52 PM
SATURNTECH9
Read my above suggestions
Sep 12, 2016 at 1:53 PM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
