rough and rich running
205,000 MILES
SCORPEON40
  • 33 POSTS
My vehicle is running rough and super rich. Service engine light flashing, but not coded code reader powers on but will not link I know 1996 was the first year mandated change over to obD 2. I have been told that my vehicle could be a 1995 and a half which means it possible that it can have a OBD 1.5. help me please.
Jul 5, 2016 at 1:19 AM
HMAC300
  • 48,601 POSTS
try another scanner first it may be an intermittent problem as well. also, check fuel pressure with a gauge should be 60-66 psi and when shut off should stay with in 5-10 psi for five minutes. Auto parts rents gauge.
Jul 5, 2016 at 2:26 AM
SCORPEON40
  • 33 POSTS
Okay I will see about another scanner. And check fuel pressure. thanks I will let you know.
Jul 6, 2016 at 2:41 AM
  • 55,743 POSTS
Those engines had a big problem with the spider injector inside the intake manifold, please remove the top half of the intake and check the pressure regulator for raw gas.
Jul 11, 2016 at 11:54 AM
SCORPEON40
  • 33 POSTS
I checked this couple days ago and I'm going to check my pressure gauge make sure that is accurate but it said I was having 87 pounds I've never seen one that much but would explain extreme rich but why
Jul 19, 2016 at 6:21 AM
SCORPEON40
  • 33 POSTS
forgot to mention that I did check with another scanner I also have a Snap-On diagnostic computer and it also would not connect
Jul 19, 2016 at 6:23 AM
HMAC300
  • 48,601 POSTS
then there is a short or bad connection at idle or wire that has power you'll have to try to find it. 87 psi is way to high check for a restricted return line and or regulator problem.
Jul 19, 2016 at 6:28 AM
