Empty/open A/C system potential damage
211,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
RDANNENFELSER
  • 43 POSTS
Can allowing an automotive air conditioning system to remain empty without pressure due to a severe unrepaired leak for an extended period of time be damaging to the system?
Sep 20, 2020 at 7:04 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
You will have to have the accumulator or receiver dryer replaced. After the repairs are completed you must vacuum the system to see if no longer leaking and then you can charge the system. Check out this video to show you how
https://youtu.be/4EqdrBVb0sY
Hope this helps and thanks for using 2CarPros.
Sep 20, 2020 at 8:45 AM
RDANNENFELSER
  • 43 POSTS
I'm planning on accumulator replacement and vacuuming the system whenever I repair the leak, but what I was trying to ask is if it would be harmful on the system to hold off on the repair until after this winter closer to warmer weather next year? Wasn't sure if it would be detrimental or not on the system to remain empty/depressurized for that many months considering lack of lubrication flow and any air/moisture that could enter the system through the leak point.
Sep 20, 2020 at 9:32 AM
DANNY L
  • 5,648 POSTS
Hello again.
No, just as I stated before in my prior post is if you have an open in the system you will need to change the accumulator at the last minute due to the fact that it acts like a filter for the system and needs to be sealed in the system for optimum performance. Here is a tutorial for you to view:
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
After repairs are made you should then vacuum the system to be sure of no leaks. Hope this helps and let me know if you have any further questions on this issue. Thanks again for using 2CarPros.
Danny-
Sep 21, 2020 at 7:57 AM
