After replacing the catalytic converter twice, the same message appears, why?
107,250 MILES • V6 • 2WD • AUTOMATIC
HAYLEYK77
I've had to replace my catalytic converter twice and now it is throwing the same message. Why should I have to continue to replace catalytic converter?
Mar 2, 2023 at 10:56 PM
  • 110,248 POSTS
You shouldn't need to replace it on a regular basis. Something is causing a problem. Can you let me know what message you are getting? Are you getting diagnostic trouble codes such as a P0420? Have you checked fuel pressure to make sure excessive fuel is entering the exhaust and damaging the converter? How is the vehicle running?
Let me know as much as you can. Also, if you have scanned the computer and have codes, let me know what they are.
Mar 3, 2023 at 1:21 PM
