vacuum/emission issue?
170,000 MILES • 1.7L • V6 • 2WD • MANUAL
JOHNYBGOOD
  • 21 POSTS
I am having a lot of problems with my car vacuum/emission, it does not sound right. When I start it feels like somethings holden it back from running well. I've changed just about everything on the motor. When I start it up and give it was the whole air housing sucks in never seen this before. Any ideas? I'm stuck this is my only ride, please help. I've TY
May 4, 2024 at 8:21 AM
  • 110,248 POSTS
When you say air housing, are you referring to the air box or air inlet tube? If so, the only way that can happen is if there is a restriction.
Let me know if that is what you are referring to. If that is, remove the air box and the inlet tube and inspect it for damage or anything that may be causing airflow to be restricted.
Let me know what you find.
May 5, 2024 at 12:45 PM
