Emissions test
230,000 MILES • 1.4L • 4 CYL • 4WD • MANUAL
FRED RIEMER
Failed emissions test.
Oct 19, 2018 at 3:14 AM
MOTOR MASTER
  • 279 POSTS
Hello my name is Dave.
First thing we need to find out is if there are any codes in the computer, if you can check that and let us know if there are codes what they are that would give us a good starting point in order to help you find the issue. Usually the MIL (check engine) light will be on if there are any but not always. And if you have any paperwork from the inspection showing the cause of the failure it would be greatly helpful to either scan them or take a picture of them and attach those copies to your next message and we will be glad to do whatever we can to help you find the problem.
Oct 19, 2018 at 4:43 AM
