emissions code p0031 p0032
150,000 MILES
DANSTADELMAN
i have a 2001 jeep grand Cherokee limited 60th anniversary edition v8
I just got check engine light when I went for inspection sticker
I got emission codes p0031, p0032
I know nothing about vehicles
can someone help please?
if there is a fix please explain it to me like I was 4 years old
I don't know mechanic lingo
thank you!
May 6, 2013 at 11:26 AM
SYMPTOM
P0031-O2 SENSOR HEATER CIRCUIT LOW 1/1
WHEN MONITORED
Battery voltage above 10.6 volts , ECT below a certain TEMP but within a set Temperature difference of Battery temp sensor.
SET CONDITION
If voltage is lower than a specified voltage at start of test.
POSSIBLE CAUSES
Fused ignition feed circuit open
Heater control circuit open
Heater element check
Intermittent condition
PCM
this is the flow chart for the codes. it most likely has a sensor that has a shorted heater., blown fuse or wiring issue
i had to generalize since you provided no engine size
May 6, 2013 at 11:33 AM
DANSTADELMAN
sorry!
4.7 liter 8 cylinder engine.
May 6, 2013 at 11:40 AM
you need a shop to track it down as there is 4 sensors which need to be checked. find a good independent repair shop to help you
roy
May 6, 2013 at 11:49 AM
DANSTADELMAN
I would if it was affordable. I am disabled and can not afford $45 per hour to diagnose the problem(that's the lowest price I was quoted) but thanks anyways for your effort. god bless. have a great day
May 6, 2013 at 11:53 AM
