emissions
205,000 MILES • 3.0L • V6 • AUTOMATIC
SMOKEYSLADY
  • 5 POSTS
I am trying to get my car to pass smog. The only mil that does not pass is the catalyst. I replaced the one that is just under the intake manifold and all new o2 sensors. I have driven the car well over four hundred miles now and the check engine light does not come on (no DTC). What could be the problem?
Nov 5, 2016 at 6:36 PM
WRENCHTECH
  • 20,760 POSTS
What is the actual reason you are failing? Is it because it is setting a trouble code or is it because the monitors have not reset?
If it is a code, give us the actual number. If it is a monitor, give us the exact monitor.
Nov 6, 2016 at 12:15 AM
SMOKEYSLADY
  • 5 POSTS
The catalyst will not pass. There are no trouble codes.
Nov 6, 2016 at 9:35 PM
WRENCHTECH
  • 20,760 POSTS
https://www.2carpros.com/images/external/85010463.gif DRIVING PATTERN The time required for each diagnosis varies with road surface conditions, weather, altitude, individual driving habits, etc. Zone A refers to the range where the time required, for the diagnosis under normal conditions*, is the shortest. Zone B refers to the range where the diagnosis can still be performed if the diagnosis is not completed within zone A. *: Normal conditions refer to the following: Sea level Flat road Ambient air temperature: 20 - 30°C (68 -86°F) Diagnosis is performed as quickly as possible under normal conditions. Under different conditions [For example: ambient air temperature other than 20 - 30°C (68 - 86°F) ], diagnosis may also be performed. Pattern 1: The engine is started at the engine coolant temperature of -10 to 35°C (14 to 95°F ) (where the voltage between the ECM terminals 70 and 58 is 3.0 - 4.3 V ). The engine must be operated at idle speed until the engine coolant temperature is greater than 70°C (158°F) (where the voltage between the ECM terminals 70 and 58 is lower than 1.4 V) . The engine is started at the fuel tank temperature of warmer than 0°C (32°F) (where the voltage between the ECM terminal 92 and ground is less than 4.1 V ). Pattern 2: When steady-state driving is performed again even after it is interrupted, each diagnosis can be conducted. In this case, the time required for diagnosis may be extended. Pattern 3: The driving pattern outlined in *2 must be repeated at least 3 times. Pattern 4: Tests are performed after the engine has been operated for at least 17 minutes . The accelerator pedal must be held very steady during steady-state driving. If the accelerator pedal is moved, the test must be conducted all over again. *1: Depress the accelerator pedal until vehicle speed is 90 KPH (56 MPH) , then release the accelerator pedal and keep it released for more than 10 seconds . Depress the accelerator pedal until vehicle speed is 90 KPH (56 MPH) again. *2: Operate the vehicle in the following driving pattern. Decelerate vehicle to 0 KPH (0 MPH) and let engine idle. Repeat driving pattern shown below at least 10 times. During acceleration, hold the accelerator pedal as steady as possible. Repeat steps 1 and 2 until the EGR system SRT is set. *3: Checking the vehicle speed with GST is advised. Suggested Transmission Gear Position for A/T Models Set the selector lever in the "D" position with the overdrive switch turned ON . Suggested upshift speeds for M/T models Shown below are suggested vehicle speeds for shifting into a higher gear. These suggestions relate to fuel economy and vehicle performance. Actual upshift speeds will vary according to road conditions, the weather and individual driving habits. Suggested Maximum Speed in Each Gear Downshift to a lower gear if the engine is not running smoothly, or if you need to accelerate. Do not exceed the maximum suggested speed (shown below) in any gear. For level road driving, use the highest gear suggested for that speed. Always observe posted speed limits and drive according to the road conditions to ensure safe operation. Do not over-rev the engine when shifting to a lower gear as it may cause engine damage or loss of vehicle control. Gear KPH (MPH) 1st 50 (30) 2nd 89 (55) 3rd 128 (80) 4th - 5th -
Nov 6, 2016 at 10:42 PM
SMOKEYSLADY
  • 5 POSTS
I have done the proper driving patterns to set the system and still everything passes except catalyst, and there are still no trouble codes(no check engine light). The diagnostic device gives me info that I am not familiar with (see image).
Nov 7, 2016 at 1:03 AM
WRENCHTECH
  • 20,760 POSTS
That is raw data that has not been processed yet. Do not worry about that.
Nov 7, 2016 at 1:30 AM
SMOKEYSLADY
  • 5 POSTS
Nov 7, 2016 at 4:05 AM
WRENCHTECH
  • 20,760 POSTS
There could be codes set that your scan tool is not seeing as it will not set if codes are stored. Other than that, it's just keep driving it.
Nov 7, 2016 at 4:07 AM
SMOKEYSLADY
  • 5 POSTS
I used a pretty decent scan tool called Mentor, and to my understanding it is a very good device. I have driven the car well over 400 miles, probably double that actually. Is there a way to get a smog waiver in California so I can get my registration renewed?
Nov 7, 2016 at 4:13 AM
WRENCHTECH
  • 20,760 POSTS
Even the best scan tools have bugs in them sometimes and miss things. It wouldn't hurt to try a different brand.
I'm from Florida. I have no idea what options you have for inspection in CA.
Nov 7, 2016 at 4:18 AM
