it starts fine especially when cold runs okay, but as it warms up say about five to ten minutes the check engine light flashes on and I notice a hesitation and or it stalls and then the check engine light will go off for a while and then re-appear. Then the same thing hesitation and or stall back and forth same thing. i have been able to retrieve the codes for the check engine light.and they are 12 and 13. this car has obd1codes. what in your opinion is causing this? I cannot figure it out. the check engine light does goes off while I am driving just to re-appear again after several minutes. i checked the codes, but it does not seem they pertain to how the car is behaving could be wrong. please help with detailed explanation. thanks. Steve
Jul 18, 2016 at 2:14 PM
