emission
111,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
CHARLES 123
check engine light stays on evap. replaced purge sol, also TPS. tried to reset will not turn off.
Jul 21, 2017 at 4:57 AM
HMAC300
  • 48,601 POSTS
make sure gas cap is tight first It should click three times after each fill up. what code is it as there are four different ones? check for vacuum lines off or broken as well.
Jul 21, 2017 at 5:01 AM
CHARLES 123
Code p0449.
Jul 21, 2017 at 5:16 AM
HMAC300
  • 48,601 POSTS
You either have a bad connection or short to ground which can be in the wire or ECM. See picture for instruction on how to test.
Jul 21, 2017 at 6:09 AM
JESSIE473
  • 24 POSTS
where is the emc located thank you
Jul 22, 2017 at 10:23 AM
JESSIE473
  • 24 POSTS
Imean the ecm
Jul 23, 2017 at 12:31 AM
HMAC300
  • 48,601 POSTS
under the left front fender close to battery
Jul 23, 2017 at 1:05 AM
