Steering is hard to control after having an alignment done
7,700 MILES • 5.7L • V8 • 4WD • AUTOMATIC
GIOVANNI_M1980
Since day 1 my vehicle had too much play when driving at speed. I decided to get an alignment that made the problem worse. brought it back then they tell me I need tie rod driver side. I get that fixed then got it realignment and it's not much better. when I'm driving on any road it's hard to stay in the middle of the lines very jerky in the steering. I just weed ant it fixed it's a family vehicle.
Jan 24, 2020 at 7:20 AM
CARADIODOC
  • 34,415 POSTS
It sounds like the vehicle was not inspected prior to the alignment. That's the first problem. No reputable specialist will align a vehicle with worn steering or suspension parts. Even if the tie rod end was missed, it would have been evident when he tried to set "toe", the direction the wheels are steering when the steering wheel is locked straight ahead. He would have been unable to make the adjustment hold solidly in alignment.
The second problem is all alignments get a test-drive afterward to verify all problems have been solved. Either that wasn't done, or the mechanic didn't drive under the right conditions to observe the problem. If he wasn't aware this only occurs at highway speeds, that was up to you to make that clear before the alignment was started.
There's something else going on besides one worn tie rod end. Have you noticed any clunking in the steering wheel? Steering wander can be caused by a number of things, worn tie rod ends being just one of them. The coupler shown in the photo is in the steering shaft under the dash. If its universal joint is worn, an alignment won't solve that cause of steering wander. You should feel the clunking in the steering wheel, and you would observe when turning the steering wheel slightly from side to side, the wheels don't respond right away.
Another, more elusive cause of steering wander is the rack and pinion steering gear is loose and sliding left and right. This can usually be felt through your feet, but can be hard to identify. The mounting design of your steering gear doesn't lend itself to falling victim to loose hardware, but it does use a pair of rubber bushings that could be deteriorated. Those are shown with the red arrows in the second photo.
The least common cause of steering wander is too little "caster". That is one of the three main alignment angles we look at on all alignments. Caster can be visualized best by looking at how the fork of a bicycle angles rearward at the top. On your vehicle, the upper ball joint is rearward relative to the lower ball joint. Up to the early to mid '60s, it was common to use "negative caster", meaning the upper ball joint was forward of the lower one. That made steering a big heavy truck without power steering fairly easy. The problem is negative caster makes for a very unstable vehicle to drive at higher speeds. Steering wander was a common problem. We started driving faster in the '60s. That's when steering wander became a bigger problem. It was solved by going to positive caster, like bicycles use, but then we had to add power steering to make up for the greatly increased steering effort needed. The trade-off for the harder steering was it made for a stable vehicle with very little steering wander.
The point of this story is there could be too little caster adjusted in that is causing excessive wander. Can you post the numbers from the alignment printout for "Camber", "Caster", and "Toe"?
Do you still hear or feel any clunking in the steering system?
Jan 24, 2020 at 9:08 AM
GIOVANNI_M1980
I got it from a dealership still making payments. they inspected the vehicle warranty expired but I still went back and told them I shouldn't be having these problems two months after purchase. I left it there they called said they found nothing wrong with it the muffler has a hole in it and that alone should have failed inspection.. to better explain what I'm experiencing low or high speed feels like the wheels shake I feel it in the brake pedal when turning on highway bends either direction it pulls very loose on straight a ways. I'll post a copy of both alignment reports and nobody drove it before or after alignment. everybody says they can't it's crazy. I live in Concord NH. how can I find a honest knowledgeable mechanic because the dealership won't do nothing. I'm trying to go after them for inspection fraud. I need water pump, muffler, tires, and rear seal on drive shaft. no way this could happen in two months. I got robbed. Thank you and i appreciate your help.
Jan 24, 2020 at 8:15 PM
CARADIODOC
  • 34,415 POSTS
Be aware there is supposed to be a small drain hole at the bottom / rear of the muffler for the condensed water vapor to drip out. People not aware of that can make it sound like it's a big deal when it really isn't.
There are so many things related to a shaking steering wheel, but there is always one thing those causes have in common. They have to involve something that is rotating, in this case, tires, wheels, brake rotors, front wheel bearings, and front half shafts. Worn steering and suspension parts can allow that shaking to occur or to be worse, but they don't cause shaking on their own. This article looks at some of these causes:
https://www.2carpros.com/articles/steering-wheel-shakes-when-accelerating-or-braking
The place I would head first is to a tire and alignment specialty shop, and give them a detailed description of what is happening. The people there are experts at finding the causes of clunks, vibrations, and bad tire wear. Very often they will insist on a preliminary test-drive where you go along to point out clues or observations. Here's a link to an article about tire wear problems, but pictures don't do a good job of showing this:
https://www.2carpros.com/articles/how-car-tires-work
A specialist will know exactly where to start looking just by running his hands across the tread and feeling the type of wear that is occurring.
The next thing we look at is how that shaking is being generated. We look for loose parts first, but there are multiple ways the vehicle has to be raised up and supported to do that. When the hoist lifts the vehicle by the frame, the suspension parts hang down freely, and that removes the tension or pressure on the lower ball joints so the wear can be seen by prying on them, but it lets gravity tug on the upper ball joints, and that prevents us from seeing any play in them. Upper ball joints have to be checked with the vehicle sitting on the tires.
Worn tie rod ends are usually very evident from simply grabbing the tire and trying to turn it left and right repeatedly.
Once loose and worn parts have been identified, we look at those rotating parts. One form of warped brake rotors can be felt during the preliminary test-drive. That is "thickness variation". It causes the brake pedal to be pushed up and down against your foot pressure, when the brakes are applied and the vehicle is moving. Think of grasping a dinner plate between your thumb and fingers. The thickness there is different than the thickness on the other side of the plate. When the thicker spot runs past the brake pads, it pushes the pads apart a little. That pushes brake fluid back up to the master cylinder and brake pedal.
"Lateral run out" is another type of warped brake rotor. There may be no thickness variation, but the entire rotor is tipped relative to its center. That causes the brake caliper to be tugged left and right once per wheel revolution. The tugging on that mass can put enough force on the steering linkage to be felt in the steering wheel and the brake pedal.
Often the shaking occurs for the first time right after some other service is performed that involved removing the wheels. If we're machining a brake rotor as part of a standard brake job, if we don't mount it squarely on the brake lathe, we'll machine a warp into it. That can also be caused by overlooking the rust that builds up on the back side in the mounting area. A chunk of that rust can become lodged behind the rotor on the lathe and cause the rotor to wobble while being machined.
Related to that, it is not uncommon for a piece of rust or scale to chip off when we're reinstalling the rotor, and it gets caught between the rotor and hub. That will cause the rotor and the wheel to wobble. It is also real common for chunks of corrosion to break off the back side of cast wheel. When the wheel is reinstalled, that chunk prevents the wheel from sitting squarely against the rotor.
A dial indicator is used to identify a bent wheel and chunks of rust or scale caught between the hub, rotor, and wheel. If excessive lateral run out is found, further inspection will reveal the cause. In this case the dial indicator is used again on the rotor after the wheel has been removed.
One of the problems we run into quite often is having to make judgement calls as to whether a part is worn enough to warrant replacement. By 100,000 miles, no steering or suspension part will be as tight as when it was new, but that doesn't mean we can justify replacing them. You have to remember, we get accused all the time of trying to sell you parts and services that aren't needed. You're accusing someone of just the opposite; so we can't win. With high-mileage vehicles, we could replace all the ball joints, tie rod ends, and control arm bushings, but that cost would show up in a higher sales price and there would be questionable improvement in the handling. The money spent would not be a good value for the dealer or for the buyer.
Part of what you described can also be caused by a bad alignment. If "total toe" is not correct, the two front tires will be steering in slightly different directions. The vehicle will follow the tire with the most weight on it, which is usually the right one. When you hit a bump or pass an intersection, some weight shifts to the left tire, then the vehicle will follow that one momentarily. You'll be constantly correcting the direction of travel.
If you feel something suddenly change or shift, especially when you're part-way through a sweeping curve, something is loose and moving around. Loose or worn mounting hardware for the steering gear, and deteriorated control arm bushings are common causes.
One thing that is often overlooked during a pre-alignment inspection is vehicle ride height. Even if all the numbers look perfect on the alignment computer, if the front springs are sagged below the published legal limit, the entire geometric relationship between the spindle, control arms, and frame will cause the wheels to not tip in and out on top as designed to reduce tire wear and improve handling. In my ten years as the suspension and alignment specialist at a very nice family-owned Chrysler dealership, I saw a lot of Dakotas and Durangos come in with the most miserable alignment readings, and well over nine out of ten ended up perfectly in specs by simply adjusting up the front torsion bars to get ride height back to specs. Every shop has a small book that lists every model and year, where to take the height measurements, and what they should be. Chrysler's method requires taking two readings per corner, then calculating the difference to get the height. While it's slightly more complicated, it eliminates the variable of optional tire sizes. Bigger tires make the truck sit higher off the ground, but that's not what we're after. It's the angles the control arms are sitting at that is important.
Jan 25, 2020 at 6:45 AM
