Emergency electric fuel pump
1994 CHEVROLET
75,000 MILES • 5.0L • V8 • RWD • AUTOMATIC
CAPT.NED
Should my electric fuel pump in tank fail could I put a electric pump in line before my filter? would it pull fuel through failed pump in tank? as emergency fix. My system is low volume throttle body 1994 G-20 3/4 ton van. Thanks
May 28, 2017 at 1:01 PM
HMAC300
  • 48,601 POSTS
as long as it can give the correct amount of fuel pressure which yours is 9-11 psi at TBI unit.
May 28, 2017 at 11:07 PM
CAPT.NED
Thanks a lot, so it would pull gas through failed pump?
May 28, 2017 at 11:35 PM
HMAC300
  • 48,601 POSTS
it should but an in tank pump is probably cheaper I think I gave the wrong pressure as well if you have port fuel it should be 41-47 PSI not the one I gave earlier.
May 29, 2017 at 12:47 AM
CAPT.NED
Thanks,you gave same pressure as guy at parts store .It is just 3/4 inch rubber fuel lines plus old style canister filter, with clamps. Electric in line pump would get me home. I used to put them on my cabin cruisers, carburetors.Thanks!
May 29, 2017 at 1:10 AM
