Emergency brake will not release?
35,000 MILES • V8 • 2WD • AUTOMATIC
ED BRUSSMAN
The automatic emergency brake is in the locked position and will not release. Tried removing the static charge and it worked for a while then locked up again. The emergency brake release is free to move. Anchors and cables are free, fuse checked. Brake actuator I do not know how to troubleshoot.
Dec 19, 2017 at 1:08 AM
  • 55,561 POSTS
It sounds like the internal valve has a leak inside the APB system. Here are some guides to help you replace the unit and get the car fixed.
Check out the diagrams (Below)
Cheers, Ken
Dec 20, 2017 at 6:23 AM
ED BRUSSMAN
I will try this fix as soon as possible.
Thanks
Ed
Dec 20, 2017 at 6:35 AM
LANGSTON56
Parking brakes stick after sitting for a week or more. The only way to release brakes is keep shifting from park to drive until parking brakes release itself. This has been happening for about six months. I am just now beginning to become concern because I feel the time is near when I am out some where and the brakes will not release.
Mar 1, 2021 at 5:48 AM (Merged)
  • 110,246 POSTS
Have you checked all cables to make sure they are not rusted and sticking?
LANGSTON56
I checked the cables,all were OK. Once I allow the car to run for a while and switch from park to reverse the brakes normally release.
  • 110,246 POSTS
I have another question. Are you in an area that it is cold? Just wondering if heat from the engine is warming something.
JENSTA
Can´t release handbrake!
-13 C and Handbrake (HB) could not be released last night, put a blancet over each wheel and a heater on each and thuoght it would varm up and relaese,but not after a night! The wheel is varm. how can I release manually?
Does not help with taking away fuse-tryed. Hope to go on business trip 6h drive ,in 4hours.
Thankful for any ideas, Jens Sweden
JENSTA
Will now share how I fixed it myself.
I took off the cables to battery for 15 min and put back again and that way "restarted" the electronic system (had to find code for radio)and then I could release handbrake. I then took away fuse to handbrake so it will not get stuck again this winter. I have a manuel gearbox so I´ll just park in gear.
WRENCHTECH
  • 20,760 POSTS
Thanks for posting the fix. That's helpful.
