ORIGINAL PROBLEM
When the original flasher stopped showing a right turn signal (dash no longer blinked and clicked, and right rear light no longer blinked), it followed that with no left turn signal (no dash blink or click and left rear light no longer blinked). Neither forward turn signal blinked. And now, even the emergency flasher button will not blink (neither dash nor either rear light).
BOUGHT A NEW FLASHER, BUT NOW, A NEW PROBLEM
The new flasher, by brand Novita and purchased locally (available at both O'Reilly and Advance Auto), is model EL12. The problem is the right rear turn signal blinks, the right forward turn signal does not, and the dash display for right turn signal blinks and clicks. Yet, the left rear light does not blink, but the left forward turn signal does, and the left signal dash display blinks and clicks.
CURRENT PLAN FOR RESOLUTION
I intend to visit NAPA for an OEM equipment solution, if possible, but now I do not believe that simply replacing the flasher relay will correct everything. If the problem is internal wiring, I already have checked the under-dash fuse array on driver's side (aware there is another, smaller array on the passenger side interior). It is unlikely the heavier relays in the engine bay are involved, but I am willing to check. I have checked the basic trunk wiring connections for the turn signal bulbs, and all rear (nighttime) driving lights light properly/
Only the right brake light indicates braking..
Although I am careful to use hand signals for turning, few drivers today may understand those signals. ..
Oct 25, 2026 at 11:50 PM
