Anti-theft, immobilizer, battery and Stabi-Trak lights turned on?
150,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
PBDM
  • 6 POSTS
1. The indicator light for theft protection / immobilizer comes on.
2. The battery indicator light comes on.
3. Stabi-Trak comes on.
At the end the engine indicator light comes on and most recently I totally ran out of car on the autobahn.
After 2 minutes with the ignition off, the vehicle listed above started again.
After a few kilometers, the game starts all over again.
Who can help?
PBDM
Aug 12, 2021 at 12:28 AM
STEVE W.
  • 15,367 POSTS
Are those lights on at initial start or do you have to drive it a while then they come on. At which point in the cycle of lights does the engine shut off?
From the description it sounds like a wiring harness or PCM issue that is causing it.
Does the theft light stay on solid when you start the truck or does it work normally until the problem happens?
Being essentially a GM Trailblazer with a Saab badge it likely has the same harness issues as it's siblings.
I would start by having a scan tool that can watch the network on it connected up and drive it until it acts up, then look to see what the tool shows, if it is the CAN network dropping out to the dash or to one of the other modules it will usually show up.
Aug 12, 2021 at 4:46 AM
PBDM
  • 6 POSTS
Hello, thank you for the answers!
At start everything is normal.
The problem only appears after a few kilometers. Once, however, even when I was still standing, but the engine was running.
The Saab is essentially a trail blazer.
My workshop had the car on a test device. However, it does not seem differentiated enough.
The following codes were recognized: U 1064, U 1192 and U 1301.
Can you do something with it?
How can the known electronics problems with the Trailblazer be resolved? For example, is it enough to replace the BCM module and reprogram it?
Can I use the CAN scanner (Controller Area Network) recommended by you to analyze the problems in a sufficiently differentiated manner?
Thank you in advance for your support!
PBDM
Aug 12, 2021 at 4:55 PM
STEVE W.
  • 15,367 POSTS
Those codes are all network communication failure codes.
U1064 - Lost Communication With Body Control Module
U1192 - Lost Communication With Vehicle Theft Deterrent
This code though suggests where the issue is
U1301 - Class 2 Data Link High
That one shows that at the time of the failure the data line is becoming shorted to battery voltage for at least 3 seconds, that will stop the network from operating and set the other errors because of the short.
The hard part will be that this condition is an intermittent one so testing for it is going to involve putting an oscilloscope or a data monitor on the class 2 data line at the data link connector then monitoring that signal as the fault happens.
Has anything been modified in this truck like an aftermarket radio? or a tracking device that connects to the OBD port?
The attached image is the data lines on that truck. Everything that says class 2 data is a suspect. It could be internal to a module or simply a wire rubbing in a door.
To narrow it down will require finding the two splice packs shown. I suggest starting with the one under the rear seat. Unplugging it and then drive around and see if the condition still happens. If it doesn't then look at the items on that side of the network first for a problem.
If you unplug that splice pack and it still happens then you will need to look at the various data modules on the other splice pack. To test those you can do somewhat the same test, namely find that splice pack under the dash and unplug it while watching the network, start the truck up and see if the problem still happens, if it does then look at the theft deterrent module for the problem as it would be the only module still connected to the powertrain control module with that splice pack disconnected. If it doesn't still happen it will be a bit harder. You would need to go to the splice pack connector and remove one of the data line pins from the connector then test drive the truck for failure. This would be repeated for each data line pin. However as you are getting the codes for theft deterrent and stability, I would suspect it is either the theft module or the brake control module. that is causing the problem.
Aug 12, 2021 at 6:05 PM
PBDM
  • 6 POSTS
A DAB + radio (Pioneer) with Android-Auto module was retrofitted.
The engine stopped after all the info lights came on one after the other and even the fuel gauge failed.
Aug 12, 2021 at 10:28 PM
STEVE W.
  • 15,367 POSTS
Okay, as a first test disconnect the radio, I have seen ones that link to the data systems cause problems, either in the radio or in the wiring to them, It may not be the cause but it's an easy item to test before digging deeper.
The data line sends signals through all of the connected systems, so a failure on any of them could result in the engine shutting off as it prevents the communication. The only good thing is that vehicle has relatively few modules to test, unlike some newer vehicles that have 3 or 4 different networks and 30 or more modules to test.
Aug 13, 2021 at 1:45 AM
PBDM
  • 6 POSTS
okay, I'll test that. I'll get back to you (may take a few days).
First of all, thank you for the great support!
Aug 13, 2021 at 2:36 AM
STEVE W.
  • 15,367 POSTS
No rush, we'll be here. I know how this testing can take a bit, especially on an intermittent issue. I've worked on some that took a week or more before the problem would happen while I had the vehicle.
One thing that might make it faster would be to test it and when it fails, don't turn off the key or disconnect anything immediately. You might be lucky and the item causing the problem will "stay broken" if the power stays on and then a scope would show it easily when you started unplugging things.
Aug 13, 2021 at 5:49 AM
PBDM
  • 6 POSTS
So it is definitely the radio !! Great note !!!
At first I switched the radio off again whenever it came on - after that the error only seldom occurred.
Then I completely disconnected the radio from the on-board network - and since then the error messages have not appeared at all.
Obviously, because the radio was switched via the ignition lock, it was constantly sending out impulses / signals via the CAN bus. At some point that is too much for the ignition lock and it throws out the error, but since the radio does not stop, the other modules connect successively and signal "Malfunction".
I am really very happy + grateful to you! How can I show my appreciation?
Kind regards
PBDM
Aug 22, 2021 at 9:20 PM
STEVE W.
  • 15,367 POSTS
Good to hear you found the issue. Unfortunately it's a common thing these days with the aftermarket items that connect to the cars networks. The issue is that there are different network communication protocols used in different brands and models and the aftermarket folks try to use a one size fit's all approach. The results vary depending on what else the network controls. On some it's just simple things like you lose the seat memory or the chimes stop working, on others it can lock up the communication buss and cause real damage.
You are welcome, please return anytime with your automotive questions, let others know about us.
Aug 22, 2021 at 9:53 PM
PBDM
  • 6 POSTS
I really like to do that!!!
Aug 22, 2021 at 10:19 PM
