Electronic throttle control light turned on
207,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
MARK SMITH4
I replaced the heater hose on my van. After the hose was replaced, when I started my engine the electronic throttle control sensor light was on, and my engine was running rough. This light had never turned on before. Was this caused by me changing my heater hose?
Jun 26, 2022 at 7:19 AM
  • 55,628 POSTS
You may have gotten something wet or bumped off a connector. We should run the codes to help guide us to the problem, here is a guide that will help:
It could be a coincidence and the throttle bore needs service this guide will show you how.
Jun 27, 2022 at 3:11 AM
