Where is the electronic spark control module located?
204,000 MILES • 7.4L • V8 • 4WD
YOSBURB
I am trying to find this part and I don't even know where it is located on my vehicle.
Oct 15, 2021 at 12:42 AM
SQM
  • 6,383 POSTS
The ignition control module is mounted next to the ignition coil. You will have to remove the intake tubing from the throttle body to access it.
Here is a helpful video:
https://youtu.be/Qws2hpduL5Q
Oct 15, 2021 at 1:11 AM
YOSBURB
I have a 454 engine and a k2500 4wd Suburban not a pickup and definitely not a 350 engine.
Oct 19, 2021 at 10:09 AM
I am attaching the info needed for this engine. Please run through this material and let us know if you need more.
Thanks
Oct 20, 2021 at 7:21 AM
