Electronic door lock issue
113,000 MILES • 2.2L • 4 CYL • FWD • AUTOMATIC
YAHSUA
Hello. I have a four door cobalt. The passenger side lock and unlock is fine but the driver side will unlock all the doors but won't lock any. I have tried to lock with the door closed, partially open and fully open without any success. It will lock at those positions. Any ideas on where I should start? This started happening about 2 months ago.
Aug 27, 2016 at 2:30 AM
RENEE L
  • 1,260 POSTS
It sounds like the drivers side switch is bad.
Aug 31, 2016 at 11:16 AM
YAHSUA
Thanks for the reply. Do I have to take the door panel off or is there another way?
Aug 31, 2016 at 11:18 AM
RENEE L
  • 1,260 POSTS
Sometimes its just the panel the switch is on, other times you must remove the panel, here is a guide to help you
https://www.2carpros.com/articles/door-panel-removal
Aug 31, 2016 at 11:19 AM
YAHSUA
Great thank you for your help!!
Aug 31, 2016 at 11:23 AM
RENEE L
  • 1,260 POSTS
No problem. Please let us know what you find so it can help others.
Aug 31, 2016 at 11:25 AM
