Electrical
2008 FORD FOCUS
214,352 MILES • 1.6L • 4 CYL • 2WD • MANUAL
SANELE
  • 19 POSTS
It display battery in dashboard then it shows all lights that normally happens. When battery drained after few minutes everything went off, but it keeps on running while there is nothing working which uses the battery. When I stop and let the engine runs maybe about fifteen to twenty minutes then there is some noise just pop something like switch than everything went to normal.
Jun 20, 2018 at 8:48 PM
HARRY P
  • 2,292 POSTS
I would start with checking the battery cables. A loose or weak battery terminal can cause all kinds of weird things to happen, including what you are talking about. Here is a guide on how to check and clean the cables and terminals yourself: https://www.2carpros.com/articles/everything-goes-dead-when-engine-is-cranked
Check it out and let us know what you find.
Jun 20, 2018 at 9:34 PM
SANELE
  • 19 POSTS
Thank you for response.
The terminals are fine but the problem is in alternator because multi-meter indicates 12 volts instead of 14 volts charging voltage, but when that noise which sounds like relay or some switch kicks then it charging normal.
Jun 20, 2018 at 9:57 PM
HARRY P
  • 2,292 POSTS
Get your alternator tested while it is acting up. The local auto parts store will test it for free. Let us know what you find out.
Jun 21, 2018 at 12:31 PM
SANELE
  • 19 POSTS
I tested it but once I have this light on it will show that it charge will less than 14 volts required.
Jun 22, 2018 at 11:48 AM
HARRY P
  • 2,292 POSTS
You should have it properly load tested. They do it for free at the local parts shop, and itis much more accurate than measuring voltage with a multi-meter/voltmeter.
Jun 22, 2018 at 12:28 PM
