The engine does not crank?
120 MILES • 5.7L • V8 • 2WD • AUTOMATIC
DAVE 30
Engine won't even crank over, have lights and Instruments, checked starter ignition, tipm module. What's next?
Mar 14, 2024 at 3:47 AM
  • 55,684 POSTS
When you try to crank the engine over do you get power to the yel/gry wire at the starter motor? If so, the starter is bad, can you turn the engine over by hand? This guide can help. Also, let's check fuse #11 and #22 inside the TIPM under the hood fuse panel.
https://www.2carpros.com/articles/engine-seized-test
This guide can help as well:
Here is how to change the starter out in case you need it and the starter wiring diagrams so you can see how the system works. Check out the images (below). Please upload a short video in your response to the problem so we can see what's going on.
Mar 14, 2024 at 10:29 AM
DAVE 30
New starter, checked TIPM, engine not seized.
Mar 19, 2024 at 2:47 AM
  • 55,684 POSTS
In the crank position do you have power to the yel/gry wire at the starter solenoid?
Please go over this guide to check:
Please go over this guide and get back to us.
Mar 21, 2024 at 4:21 AM
  • 55,684 POSTS
anything?
May 11, 2024 at 5:32 AM
