Engine revs when I turn off side lights
24 MILES • 1.5L • 4 CYL • 2WD • AUTOMATIC
FRANCO1
When I turn off the side lights the engine revs falter (reduce) for a couple of seconds. It does not happen if I turn off other appliances.
Nov 28, 2018 at 7:16 PM
  • 55,694 POSTS
It sounds like the throttle bore is dirty. Start by disconnecting the battery and then following this guide.
Here are the headlight wiring diagrams so you can see how the system works. Check out the diagrams (below). Please let us know what you find. We are interested to see what it is.
Cheers, Ken
Nov 30, 2018 at 4:25 AM
