Electric power steering stopped working?
2012 FORD FUSION
154,380 MILES • 2.5L • 3 CYL • 4WD • AUTOMATIC
LADYJ19801
My car listed above's electric power steering went out in my car. The steering wheel is locked, and I can't drive it. It won't accelerate or do anything. On the dashboard it says power assist service now. I don't know what it is, one mechanic said rack pinion, and another said ignition lock cylinder. I need help please.
Oct 12, 2022 at 8:32 AM
  • 110,240 POSTS
The message can be the result of a few things. To assume it is one thing is not a great way to diagnose the issue. I'm not sure why someone told you it was the steering wheel lock.
What really needs to be done is to scan the can-bus system for codes.
CAN stands for controller area network. Basically, the different computers/modules are tied together via a few wires. This type of scan will retrieve codes regardless of the module storing them.
Here is a link that explains how it's done:
If I had your vehicle in my shop, this is where I would start. This type of scan will eliminate things and point you in the right direction for repair.
Let me know what I can do to help or if you have other questions.
Oct 12, 2022 at 1:47 PM
