Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Subaru
Legacy
Electrical
Ignition Switch
my ignition key is switched over?
2001 SUBARU LEGACY
429,000 MILES • 2.5L • 4 CYL • 4WD • MANUAL
JAYDEN MURRAY
MEMBER
My cars electricals wont turn on until my ignition is switched over to acc
Sep 6, 2025 at 8:33 AM
Experienced Mechanic
That is an easy one, you need to replace the ignition switch. Here is one for $61.00 on Amazon.
https://amzn.to/3V0h5Ml
Let us know if you need anything else.
Sep 6, 2025 at 10:16 AM
JAYDEN MURRAY
MEMBER
If that doesnt work?
Sep 6, 2025 at 11:50 AM
NP, lets do some testing to make sure this is the problem. Use this guide to help check for power at the green wire when the switch is in the "on" position. if not the switch is bad.
Please go over this guide and get back to us.
Sep 7, 2025 at 2:03 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
