Coils number one and three not firing
1,000 MILES • 4 CYL
CLEMENT SILUYASILA
coil number 1 and 3 are not firing, while number 2 and 4 are firing. what could be the problem?
Dec 24, 2019 at 11:21 PM
  • 110,248 POSTS
Please understand, this vehicle isn't offered in the US, so my technical information is extremely limited. However, I will try my best to help.
Did the problem happen all at once? Also, what diagnostic trouble codes have been found? If you switch coils 1 and 3 with 2 and 4, does the misfire change cylinder?
Dec 25, 2019 at 11:12 AM
CLEMENT SILUYASILA
The problem just happened at once, and there are no diagnosis trouble that have been found and when you swap the coil they start firing.
Dec 25, 2019 at 4:54 PM
