coil number 1 and 3 are not firing, while number 2 and 4 are firing. what could be the problem?
Dec 24, 2019 at 11:21 PM
✓Experienced Mechanic
Please understand, this vehicle isn't offered in the US, so my technical information is extremely limited. However, I will try my best to help.
Did the problem happen all at once? Also, what diagnostic trouble codes have been found? If you switch coils 1 and 3 with 2 and 4, does the misfire change cylinder?
Dec 25, 2019 at 11:12 AM
CLEMENT SILUYASILA
MEMBER
The problem just happened at once, and there are no diagnosis trouble that have been found and when you swap the coil they start firing.
