all the lights in my dashboard go on and off without stopping and nobody can not tell me what it is. HELP!
Dec 5, 2016 at 9:15 AM
HMAC300
✓Experienced Mechanic
have a mechanic scan for codes. it is either a dash problem wiring issue or a body module problem.
Dec 5, 2016 at 11:11 PM
ALFREDOBOHORQUEZ
MEMBER
thank you very much.!
Dec 6, 2016 at 2:35 AM
SOKRAT GEGA
MEMBER
hi,
maybe your problem is ignition key check all terminals in you key when turn ignition on to see voltage on terminals 15, 15R, 15L etc.
sorry for my bad english.
Dec 6, 2016 at 4:43 PM
Defiantly sound like a problem with the electrics do what has been suggested and also make sure all body earths are clean and tight and make sure that the battery is in excellent condition get a load test done, as low or unstable battery voltages can cause odd problems like this.
