ELECTRICAL PROBLEMS WITH 2007 TOYOTA YARIS S
102,000 MILES
ORLANDOFGR1
  • 5 POSTS
PURCHASED 2007 TOYOTA YARIS S SEDAN SIX YEARS AGO WITH NO PROBLEMS AT ALL.RECENTLY, I DROVE TO A FAST FOOD RESTAURANT AND AS SOON AS I PARKED,THE A/C, AND THE RADIO STOPPED WORKING.ALSO THE POWER WINDOW AND THE KEY BEEPER.WHEN I WAS ABOUT TO LEAVE ALSO NOTICED THE P/S SYMBOL ON MY DASH AND THE STEERING WHEEL WAS HARD TO TURN.I TRIED TO RELEASE THE SHIFT FROM PARKING AND IT WOULDN'T BUDGE SO I PUSHED THE RELEASE BUTTON.AFTER A FEW CHECKS ON RELAYS AND FUSES ,FOUND NOTHING.THEN I DISCONNECTED THE BATTERY AND CONNECTED BACK AND EVERYTHING WENT BACK TO NORMAL.FIVE DAYS LATER IT HAPPENED AGAIN BUT THIS TIME FOR A MOMENT AND THE BATTERY SYMBOL WENT ON A FEW SECONDS AND THEN OFF.HAVEN'T BEEN ABLE TO TAKE IT FOR SERVICE SINCE THERE IS NO SERVICE CODE OR CHECK ENGINE SYMBOL AND IT WORKS FINE.
May 30, 2013 at 6:29 AM
KHLOW2008
  • 41,812 POSTS
Seems like you have a possible power supply interruption somewhere intermittently and such problems are not easy to diagnose unless you are able to perform testings when it occurs,
Check the connections under the fuse box for poor connections. Have a DVOM handy. When problem occurs, use the DVOM to test the power supply from battery to main fuses and fusible links.
Jun 1, 2013 at 5:36 PM
ORLANDOFGR1
  • 5 POSTS
Thanks for the info! I thought the same thing, just haven't checked it with a multimeter yet, i'll get on to it before it happens again.
Jun 1, 2013 at 10:57 PM
KHLOW2008
  • 41,812 POSTS
You're welcome.
Good luck.
Jun 3, 2013 at 6:09 AM
ORLANDOFGR1
  • 5 POSTS
Found the problem! Just don't know what its called. I think its a fusible link located at the positive battery terminal. I think i can repair it but really need to replace it. If anyone knows the name or part number please reply, will appreciate very much!
Jun 5, 2013 at 11:14 AM
KHLOW2008
  • 41,812 POSTS
You already got the name correct, fusible link.
Jun 6, 2013 at 2:46 AM
ORLANDOFGR1
  • 5 POSTS
Tkanks! Needed to make sure what i'm asking for.
Jun 6, 2013 at 3:05 AM
KHLOW2008
  • 41,812 POSTS
Simple way is to show the parts people the component.
Jun 6, 2013 at 3:13 AM
ORLANDOFGR1
  • 5 POSTS
Got it replaced, back to normal! Can't thank you enough!
Jun 8, 2013 at 11:13 PM
KHLOW2008
  • 41,812 POSTS
You have thank me sufficiently.
Have a nice day.
Jun 9, 2013 at 1:57 AM
VIERY13
Hello sir, this is my first time in a forum so please forgive me if I screw it up. I really need your help. I have ran to the same problem with my 2007 toyota yaris. The only thing i did not do was disconnect the battery and reconnect it. How were you able to fix the problem? A mechanic looked at my car today and wants to charge me $300 for identifying the problem, he says is the junction box and wants to replace it and charge me $1200 for the whole job!
Once again how did you find out what the problem was? And how did you fix it. Thank you for all your help.
Respectfully
Henry
May 14, 2014 at 9:28 AM
KHLOW2008
  • 41,812 POSTS
A power supply connection is loose somewhere and one way of testing is to use a DVOM to check for missing links. Try tugging lightly at the fusible links attached to the battry positive terminal and checking to see if things stops working.
May 18, 2014 at 12:07 AM
