Electrical Problems when steering - Very Strange.....
2005 NISSAN PRIMERA
96,000 MILES • 2.2L • FWD • MANUAL
D_ROX_7
This is a wierd one, so hope you can help.
When i have my headlights on, steering left or right round a corner starts to trigger the volume, change radio stations or change from CD to radio & viceversa. This doesn't happen when the lights are switched off.
Only discovered this problem moving into winter when i need my lights more.
Any thoughts?
Thanks,
David
Dec 27, 2013 at 1:59 AM
CARADIODOC
  • CAR REPAIR CONTRIBUTOR
  • 34,309 POSTS
I suspect you have lighted switches on the steering wheel. If the clock spring is coming apart, it can short multiple circuits together just as if you were pressing a switch. With the lights turned on, one of those circuits will be live, and it is probably touching another circuit when you turn the steering wheel.
Dec 27, 2013 at 10:43 AM
