Our SUV was driving fine then this morning went to start it and it was dead. Charged the battery and now sounds like it wants to start, but wont turn over. Theft light flashing, odometer light stays lit up and defrost comes on and will not shut off even with key out when trying to start it so we have to disconnect the battery to shut defrost off. I thought with theft light blinking maybe anti theft was causing a problem and needed to be disconnected, but do not know even where to find it under the hood. That does not explain defrost coming on though with out turning it on when trying to start the engine and then it not shutting off even with key out of ignition. What do you think it is? Thank you for your expert advice!
Sep 2, 2016 at 10:53 AM
