not get power unless on jumper cables but still will not start?
143,000 MILES
JOIMM
Car will not get power unless on jumper cables but still will not start. Just replaced alternator and battery. Need help.
Aug 8, 2023 at 9:22 PM
  • 55,732 POSTS
I have seen the TIPM go out and cause this problem, but to be sure we should do a CAN scan, you can get a CAN scanner (Controller Area Network) which will work on most cars from Amazon.
here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
Here is how to change the TIPM out which is easy because it-self learns in the images below. Check out the images (below). Please let us know how it goes.
Aug 10, 2023 at 5:15 AM
