Electrical problems
230,000 MILES • 3.8L • 6 CYL • FWD • AUTOMATIC
PONTIACTROUBLE
I believe my problems may have started with a leaking sunroof, water getting into the interior of the car. Now the tachometer, speedometer, turn signals, odometer, drivers information center, rear door windows and locks, and cruise control will not work. It would at least run, but now it will not start. It will cranks over, but no sound of ignition.
Feb 26, 2016 at 4:20 AM
HMAC300
  • 48,601 POSTS
Try resetting security system or another key. Also check all fuses then scan for codes and check fuel pressure with a gauge most auto parts stores rent it.
Feb 26, 2016 at 8:05 AM
RENEE L
  • 1,260 POSTS
Here is a video that should be of help to you.
www.2carpros.com/articles/how-to-check-fuel-system-pressure-and-regulator
Apr 6, 2016 at 7:28 AM
