Electrical problems
144,000 MILES • 2.5L • 6 CYL • 2WD • MANUAL
AL3X770
Hi, my can wants to stall and voltage drop whenever I turn on headlight and shuts off completely when I press the brake pads. When headlight is turned on alternator is charging at 13.90 volts and battery is new.
Jul 28, 2018 at 5:39 PM
  • 110,248 POSTS
HI and thanks for using 2CarPros.com.
The voltage you mentioned sounds right on target, so I do not think the problem is electrical or at least not the alternator.
What I think may be happening is the brake booster is bad and when you apply the brakes, it drops the engine vacuum causing the engine to stall.
I first want to check if there is a vacuum leak issue. Here is a link which describes how to check engine vacuum. Do this and let me know what you find.
Let me know if you have other questions or need help.
Jul 30, 2018 at 11:15 AM
