ECM keeps blowing, headlights stop working, turn the headlights on and the truck shut off?
300,000 MILES • 2.8L • V6 • 2WD • MANUAL
CHRISTOPHER ANDERSON
I keep having electricity problems, ECM keeps blowing, headlights stop working. I got it running yesterday and when I tried to turn on the headlights on it cut off and won’t start back up. All fuses are good. Please help.
Oct 27, 2021 at 12:30 PM
Good morning,
I would first test the battery and make sure it can handle loads. If the battery is low, it will shut off the engine when the headlight is commanded on.
https://www.2carpros.com/articles/symptoms-of-a-bad-car-battery
Do this test and let me know the results. Power is always the first thing we check when in this situation.
Oct 27, 2021 at 8:06 PM
