Ignition lights, battery, lights, oil lights fails to go off?
2,300 MILES
ADAE BUHARI
Ignition lights, battery, lights, oil lights fail to go off when the vehicle is in motion. Cluster lights stay on when engine is turned off leading to battery failure Key remote fails to open or lock doors Indicators fail to show on dash.
Oct 20, 2024 at 9:00 AM
  • 55,858 POSTS
Yep, this will happen when the instrument cluster needs to be replaced or you have a bad ground. here is how to remove the cluster so you can check the ground and then replace the unit with a rebuilt or used unit you can find on eBay. Here is a guide to help you test the black wire at the cluster electrical connector. Also, I have seen if you disconnect the battery overnight sometime the cluster will start working again.
Oct 20, 2024 at 11:22 AM
