Turn on hazard lights interior lights start flashing and small display in the speedometer also flashing
192,700 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
GIGISULAMANIDZE1
  • 88 POSTS
Hello, when turning on hazard lights interior lights starts flashing and small display in the speedometer also flashing. new alternator, cleaned negative cable, all ground cables. still have this problem.
Apr 11, 2019 at 12:21 AM
  • 55,808 POSTS
It sounds like the GEM is out. here is instructions and guides to help you change it out to fix the problem. Check out the diagrams (below). Please let us know what you find.
Apr 12, 2019 at 4:13 AM
GIGISULAMANIDZE1
  • 88 POSTS
Also, when i press brake pedal light flashes little bit.
Apr 14, 2019 at 5:20 AM
  • 55,808 POSTS
Yep, these are controlled by the GEM can you try to replace it to see what happens?
Apr 16, 2019 at 3:58 AM
