When I set the alarm or lock the doors the outside and inside lights stay on
2003 LINCOLN NAVIGATOR
155,831 MILES
SHAWN ROSEBORO
Now I've been seeing the door open on the dash. I've had to jump start the truck on a few mornings. The battery, starter and alternator are all fine I can't find any of the fuse's gone bad. I hope someone has an answer for me thanks..
May 6, 2013 at 10:07 PM
CADIEMAN
  • 3,544 POSTS
disconnect the fuse for now.it is most likely a bad timer in the alarm or entry module.
May 6, 2013 at 10:26 PM
WRENCHTECH
  • 20,761 POSTS
The switches that control the lights for open doors are made right into the door latches and they have a history of sticking and causing problems like that.
Here is a technique that often works well and eliminates the problem at no cost.
Get a can of spray lube like WD40 or something like it and has a straw on the nozzel. Spray it generously up into the latch mechanism. Now open and close the door numerous times to work it in. Repeat this process several times. Since you don't really know which door is causing the problem, you should do all of them. It's usually caused by the most frequently used door but it's not guaranteed to be that one.
May 6, 2013 at 10:49 PM
