Electrical problem
20,000 MILES • 4.2L • 6 CYL • 2WD • AUTOMATIC
CHILIE WILLIE
When I turn on high beams it stalls and when low beams are on and I turn my left turn signal on the right light blinks with it, doesn’t happen on the other side. All relays are good as well as fuses.
Dec 2, 2019 at 3:12 AM
AL514
  • 5,700 POSTS
Hello, it sounds like the body control module may have gone bad, or you have a wiring issue. Is the check engine light on?
Dec 2, 2019 at 9:29 PM
CHILIE WILLIE
No check engine light and no codes.
Dec 3, 2019 at 12:45 AM
AL514
  • 5,700 POSTS
Somethings going on with the body control module. It controls all the blinker circuits and is in communication with the engine computer. Unless there's a bunch of wires that have melted together. All the power and ground wires to the body control module need to be checked.
Dec 3, 2019 at 1:04 AM
CHILIE WILLIE
Okay, I will start checking and let you know. might take a minute. I do have a BCM from my other Trailblazer can I swap them out?
Dec 3, 2019 at 1:19 AM
CHILIE WILLIE
Can I use the BCM from another Trailblazer without having to reprogram it?
Dec 3, 2019 at 3:37 AM
AL514
  • 5,700 POSTS
You can try unless it's a wiring issue.
Dec 3, 2019 at 4:19 AM
