electrical power shut down
110,000 MILES • 4 CYL • 4WD • MANUAL
CELTIC23
When I turn on my blinker my jeep shuts off and it will not start for a while. My lights will still turn on, but my dash board and my radio will not turn on and I cannot start my jeep. Please help.
May 11, 2016 at 10:58 PM
HMAC300
  • 48,601 POSTS
fuse 2 under hood powers starter relay and stop lamp switch it is a pink/black wire then pink/blue I think to stop lamp see if that wire is grounding out on something. then check hazard flasher under dash left hand side. the radio may need a ground wire leading to it also check ground wire at left hand kick panel.
May 11, 2016 at 11:21 PM
