Electrical, lights and ignition
160,000 MILES • 2.4L • 4 CYL • 2WD • MANUAL
KOZZY85
All lights in the car flicker randomly ignition does nothing, all lights fully come on when brake pedal is pressed. Turn the key and nothing happens.The car was fine besides the starter not engaging, so I replaced the negative battery cable and that is when all these problems started. I put the original battery cable back on and it is still happening. Before I changed the cable we could bump start the car and it would run fine but not now.
Oct 25, 2017 at 1:43 AM
STEVE W.
  • 15,411 POSTS
Check both the ground and positive side battery cables, Be sure the body grounds are good as well as the battery itself. An internal break in the battery could cause this just as easily as a bad cable.
But be very careful. If there is a break inside the battery it could spark, that could cause the battery to explode as they have a hydrogen gas in them from the charging process.
Flickering lights that get better under load suggests a bad ground or battery.
Oct 25, 2017 at 4:28 AM
