Headlights started flashing and clicking the car was off and the lights were off
289,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
ROSEANNA135
  • 6 POSTS
My car headlights started flashing and clicking while I was asleep. The car was off and the lights were off. It doesn't stop flashing when you try driving it and it shuts off at idle now. The clicking noise was coming from a relay that I unplugged at one point but it only stopped the high beams. Problem still exists. I had to disconnect battery to make it stop.
Dec 2, 2019 at 11:02 PM
More than likely you have a relay, fuse, or wiring issue. Do they flash consistently or is more of a flicker? Maybe post a video of how they are flashing when the engine is running.
However, I posted the wiring diagram of the headlamps. Looks like you have two relays for the DRL that power the low beam fuses. If one of these is failing it will actually click on and off rapidly which can flash the headlamps.
Is there a horn chirp or anything else going off with this? Again a video will help get us on the same page.
Dec 3, 2019 at 1:37 AM
ROSEANNA135
  • 6 POSTS
There is surprisingly no horn chirp.
Dec 3, 2019 at 2:39 AM
ROSEANNA135
  • 6 POSTS
I am sick at the moment. First chance I get, I will upload a video. Thank you so much for responding.
Dec 3, 2019 at 2:45 AM
Okay, thanks. I think a video will help get us on the right path. I will wait to hear back.
Dec 3, 2019 at 11:15 AM
ROSEANNA135
  • 6 POSTS
Here is a video:
Dec 3, 2019 at 11:04 PM
Yep. That is a failed relay or a short in the circuit. The clicking that you feel is actually the relay opening and closing the contact rapidly.
Check out the guide on how to test it. I would just replace it and if the new one does it then you need to start wiring testing.
Great job with the video. That really helped!
Dec 4, 2019 at 10:41 AM
ROSEANNA135
  • 6 POSTS
Thank you. You have been more than helpful. Saving grace!
Dec 4, 2019 at 11:25 AM
You are very kind. Thanks for using 2CarPros. Please come back when you have other questions. We are here to help. Thanks
Dec 5, 2019 at 9:48 AM
ROSEANNA135
  • 6 POSTS
I most certainly will. Thank you very much for the help and patience.
Dec 5, 2019 at 9:54 AM
