Electrical issues, battery draining
135,000 MILES • 2.4L • 6 CYL • 2WD • AUTOMATIC
JASON PETTINATO
I bought the car listed above about 2 years ago, and it has had many electrical problems since. Headlights randomly dimming, internal lights sometimes not working, slow power windows, etc. Recently my car has been not turning when I turn the key in the ignition, with only a small click when I turn it initially. I measured the voltage of the battery and when it is off I measure about 11.8V, and when it occasionally turns on I get 14.2V. I'm thinking either a bad alternator or some form of electrical draining is going on, I would appreciate some help with this one. Thanks.
Dec 15, 2020 at 12:54 AM
Good afternoon,
Your battery is no good. It needs to be 12.6 volts to be full charge.
https://www.2carpros.com/articles/how-to-charge-your-car-battery
Then you need to recheck the charging system.
I attached a wiring diagram for you to view.
There are fuses to test and wiring to be checked for the system.
Dec 15, 2020 at 3:08 AM
JASON PETTINATO
Thank you, I'll get that done. Darn Walmart batteries it's only 9 months old.
Dec 15, 2020 at 5:35 AM
You are welcome.
Keep us updated.
Dec 17, 2020 at 8:41 AM
