Electrical issues diagram of the engine computer pinout needed?
182,000 MILES • V6 • 2WD • AUTOMATIC
FLICK23
In need of a diagram of the engine computer pin out. Would like to run some tests.
Jun 7, 2023 at 4:29 AM
AL514
  • 5,700 POSTS
Hello, there are 6 pages for the ECM diagrams, we will be happy to post them for you. It will be 2 diagrams for each page, top and bottom, so you can print them out and tape them together. Just give us a few minutes.
Diagrams 1,2- 3,4 - 5,6 - 7,8 - 9,10 - 11,12 go together, I will go through the OEM diagrams to verify these are correct. Any differences will be posted shortly.
Be careful when testing with certain incandescent test lights, they can pull too much current for certain ECM circuits.
There is a list of Technical Service Bulletins for the ECM.
https://www.2carpros.com/articles/how-a-car-computer-works-pcm-ecm-bcm
https://www.2carpros.com/articles/how-to-replace-a-vehicles-main-engine-computer-pcm-ecm-ecu
Jun 7, 2023 at 4:37 AM
FLICK23
AL514, you're the best!!! I know it was a lot to put together. So, thank you and i will keep you posted. When I get a few minutes I'll explain the details of the problem. Maybe it will help someone else.
Jun 8, 2023 at 7:00 AM
AL514
  • 5,700 POSTS
Okay, that would be cool. We would like to know what the testing is for and possible repair. It always helps with future issues. Thanks.
Jun 8, 2023 at 9:31 AM
