Starts but will not stay running?
185,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
1998Z71
  • 6 POSTS
Truck was running fine with a small misfire then I decided to check the codes with an obd2 scanner. well, it pulled up the same ones it had last year. Now keep in mind I had the truck running to see if it would pull any new codes and it didn’t so, I tried to clear the old codes and as soon as I did the truck shut off and it will not stay running anymore. It will start and run for about 2 seconds then it shtus off. Security light is on, but it has been on for about 2 weeks with no issue.
Jul 15, 2023 at 9:24 AM
  • 55,676 POSTS
What are the codes? It sounds like the fuel pump has gone out, if you turn the ignition on without cranking the engine over can you hear the fuel pump run in the tank for about 5 seconds? If not let's see if the engine will run on starting fluid. Here is a guide to help us get started and I have included how to change the dual pump out in case you need it. If the security light is not flashing the system is not enabled.
https://www.2carpros.com/articles/car-not-running-advanced
Jul 16, 2023 at 3:33 AM
1998Z71
  • 6 POSTS
Yes, I can hear the pump running when I turn the key on. But I can also keep the truck running with carb cleaner if I have somebody spray it when I start the truck. And the check valve on the fuel line has enough pressure that the gas will spray the bottom of the hood when I press it but I don’t have a don’t have a tester to actually test the fuel pressure.
Jul 16, 2023 at 6:23 AM
1998Z71
  • 6 POSTS
P1345 and p1153.
Jul 16, 2023 at 8:30 AM
1998Z71
  • 6 POSTS
I have already replaced camshaft and crankshaft sensor last year, but the code was stored in the memory. That’s why I tried to erase them and when I did it shut off the truck and now it won’t stay running. It starts for about 2 seconds then shuts off.
Jul 16, 2023 at 8:33 AM
  • 55,676 POSTS
So, the P1345 code is for the crankshaft sensor so you may have a defective part. Is the security light flashing?
Here is more information on the codes:
P1345: This code refers to a problem with the crankshaft position sensor (CKP) or its correlation with the camshaft position sensor (CMP).
P1153: This code is related to the oxygen sensor (O2 sensor) on Bank 2, Sensor 1.
Jul 17, 2023 at 3:34 AM
1998Z71
  • 6 POSTS
This issue I’m having is to do with fuel I have already fixed the crankshaft sensor problem. I had to replace the timing chain cover cause the sensor kept pushing out under load. The problem I’m having now I believe the computer is shutting off the fuel pump right after start up. I can keep the truck running with choke cleaner, but it shuts off as soon as I stop spraying.
Jul 17, 2023 at 5:55 AM
  • 55,676 POSTS
Is the security light flashing? Also, I would check the fuse for the PCM. Does this truck have two fuel tanks?
Jul 18, 2023 at 3:07 AM
1998Z71
  • 6 POSTS
Okay, I got the truck running. I had a friend with a good scan tool to check and clear the computer. But I have a question about my air conditioner. Last year it worked fine and now this year I can’t get the compressor to engage unless I run a hot wire straight to the green wire on the compressor. But then it doesn’t cycle, just stays engaged.
Jul 18, 2023 at 12:39 PM
  • 55,676 POSTS
Glad you could get it fixed, thanks for letting us know. Please use 2CarPros anytime we are here to help.
Sorry we only handle one problem per thread, please post your new question here, you must be logged in.
Cheers, Ken
Jul 20, 2023 at 3:12 AM
