Recently my car has run into some electrical issues.
The car basically refuses to start. It will click, but not start.
My cable ends of the battery were a little corroded, so I cleaned the posts and the terminal ends up. If the car jumps with no issue and runs, does this essentially mean the cables are not the issue?
I bought a schumaker battery charger and "bad battery" comes up with charging, although I am not sure how accurate that is considering it also says "bad battery" if the battery is sulfated, where the manual says to keep charging.
Also, after the last attempt at jumping, the car had some weird noises. It sounded almost like electricity was pulsing, the sub-woofer was making some noise, etc.
I just connected the battery up to the car and attempting to start it had a small click, but a yellow/orange light on the radio started flashing rapidly. Any ideas?
Jul 11, 2016 at 6:41 PM
