electrical issue with ECM
2001 MITSUBISHI ECLIPSE
140,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
STEVE GRASSINI
  • 11 POSTS
radio, clock, interior lights went out. Central lock only works with key on. I replaced all fuses..But car now fails smog test. Tech reset ECM and won't pass now. I purchased a scanner to check for readiness, and after I get them all ready, as soon as I shut car off and disconnect scanner, ECM reverts back to not ready... Please help...Need to bring it back through emissions soon.
May 25, 2020 at 9:23 AM
  • 110,244 POSTS
Either there is power loss to the PCM or the PCM no longer holds memory. Do me a favor. Take a look at the attached portion of the wiring schematic. Check the fuse I indicated. That fuse provides power all the time to the PCM. Make sire it is good. The only way this should be happening is if the codes are being cleared by the scanner or if the battery is disconnected (power loss).
May 26, 2020 at 3:00 AM
STEVE GRASSINI
  • 11 POSTS
Hello. After looking at the diagram, not sure what fuse your indicating. I did change all fuses in car with the fuses that light up when blown. My car did recently have work done, throttle body and idle valve cleaned and PCM cleared or reset. I've used a scanner and have done road test and actually had all monitors ready. I shut car off, unplug scanner, remove key and if I try right away, still good. But after a minute or 2, monitor revert back to not ready. Again, all fuses have been replaced unless there's one I'm not finding or maybe a relay. Just frustrating as time for recheck is approaching quickly. Thanks for your help.
May 26, 2020 at 6:04 AM
  • 110,244 POSTS
The PCM should have power at all times. When power is lost, so are the readiness indicators. To the best of my knowledge, fuse 4 is the one that provides constant power for the PCM. Take a look at the pic and let me know if it helps.
May 26, 2020 at 3:01 PM
STEVE GRASSINI
  • 11 POSTS
I've replaced them all. Everything was working good 1 night, and next night, no dome light, clock, radio, and central door locking issue as well as car wanted to stall at stop light once car was warm and not on high idle. All happened at once. Tech said he cleaned parts I mentioned earlier and said he cleared PCM, but doesn't remember if there where any codes. No check engine light was ever present. I have read others have had this issue, but none so kind as to post resolve if any. I'm getting nervous now...
May 26, 2020 at 3:31 PM
  • 110,244 POSTS
First, reconfirm that all grounds are good, specifically body grounds. I spoke with another tech regarding this. Basically, he indicated this car has a ETACS ECU and the main engine ecu, and suggested you needs to do a CAN scan to see which one is bad.. He is leaning toward the ETACS ECU. Additionally, he indicated that the "Stay Alive" battery is internal and if it has failed, the PCM will need replaced.
CAN stands for computer area network. It ties all the modules together. Here is a link that explains how to scan the CAN system on your vehicle:
https://youtu.be/InIlnsjOVFA
Let me know what you find.
May 27, 2020 at 1:34 PM
STEVE GRASSINI
  • 11 POSTS
Hello, I'm a little confused here.. The ETACS ECU is on drivers side near fuse box??. If ETACS ECU battery is dead, why would PCM need replacement? Is the battery built in PCM or ETACS ECU?? If it were the ETACS ECU, what could be wrong with it?
Jun 1, 2020 at 2:53 PM
STEVE GRASSINI
  • 11 POSTS
Also, I'd like to add that the constant power wire, (the 1 that keeps memory) to the radio is powerless. I assume it's the same at PCM. Whatever is going on makes the car shift funny at times and temp now reads slightly above the middle mark (which it never has before). I've gone so far as to swap around any relays that are the same under hood as well as the 2 in fuse box... The 2 relays in fuse box make 1 click noise when I turn car on. I replaced 1 of them just to C if that help. No go. Something killed the memory power supply to certain things. And it all happened overnight... I've been going crazy reading tons of stuff...most which have no conclusion.. Some1 has to have experienced this problem before... I can't be the only 1...
Jun 1, 2020 at 3:41 PM
STEVE GRASSINI
  • 11 POSTS
I have another thought after reading an article earlier this evening. A few weeks before my problems stared, I had an Xtant X1001 amplifier burn up on me when car was left warming up. I came outside to find a burning smell and when I entered the car, a few seconds later a loud pop and tons of smoke from amp. I pulled amp out immediately. Drove car and it was fine. (Car is hardly ever driven as it's our once in awhile ride.) So a few weeks of no driving and I decided to put an old school power hungry amp back in it's place and all was working good... One night I decided to take car to store a few mile at best...all was good... I came home music blasting. Everything was good. Next day, problems as stated earlier in post started....boom just like that....no radio, clock, dome light, and central doors on work with key on...also found out once car was warm it wanted to stall at stops. I since removed that amp also, and added a newer more power friendly amp...and rewired my stereo memory power to horn fuse and all is good with sound system...Sorry for the lengthy post but trying to give U everything in a nutshell... My question here is, I read that.. When the alternator diode pack fails it can leak AC voltage which can cause disruptions in the electrical system including causing premature battery failure. It can also cause other electrical components such as the radio and gauges to act strangely. Could this interrupt PCM?? I was thinking if I had a diode pack problem and AC voltage went into the battery, could that have burnt up my amplifier? It has a large 60 amp fuse straight from battery going to amp and maybe a small amount of AC current made it's way through fuse and into amp. Whatever the case, the amp was destroyed beyond repair...(Blew a large capacitor and burnt some off the board. Please lend your thought. This is the damage to my amp.
Jun 1, 2020 at 4:08 PM
STEVE GRASSINI
  • 11 POSTS
Hello, I spoke to my tech today and he says my car is too old to preform a CAN scan of the system.. It's a 2001. Is he correct?
Jun 2, 2020 at 11:00 AM
  • 110,244 POSTS
Although the system may be primitive, he can scan the can buss system. However, I honestly feel the ECM is bad.
Jun 2, 2020 at 1:18 PM
STEVE GRASSINI
  • 11 POSTS
earlier in post, you mention internal battery. Is that in PCM or ETACS ECU? You stated if internal battery was bad, PCM would need to be changed... Just confused as you indicated you believe it's the ETACS... Is this the 1 near passenger foot compartment or near fuse panel on side of dash?
Jun 2, 2020 at 1:28 PM
STEVE GRASSINI
  • 11 POSTS
Just an update. I brought car to Mitsubishi tech today and he diagnosed the problem as being a broken wire in the left fender well. Repair to happen Monday and I will surely keep you updated if this works.. Could help someone else out.. Stay tuned....
Jun 3, 2020 at 11:46 AM
  • 110,244 POSTS
Let me know. I'm really interested in knowing what wire and if it takes care of the problem.
Jun 3, 2020 at 2:18 PM
STEVE GRASSINI
  • 11 POSTS
As promised, here's the update: please share with whomever has similar issues. 2 broken wires in harness the runs through left fender. No dome light, clock, radio. and central locking issue. Also, it would not pass emissions for readiness monitors because the ECU wasn't getting power. The tech found issue within an hour 27 years with Mitsubishi.. So now the car runs perfect and shifts better as well (was shifting a little funky,) flare between 2nd and 3rd. Well that's it. Back to good. I've attached pics of wires.
Jun 8, 2020 at 8:57 AM
  • 110,244 POSTS
Thanks for letting me know. I have a feeling, it will help others in the future.
Jun 8, 2020 at 1:03 PM
STEVE GRASSINI
  • 11 POSTS
You're welcome. Thanks for your help.. So glad that it's fixed.
Jun 8, 2020 at 2:18 PM
  • 110,244 POSTS
Steve, if I was able to offer any help, you are very welcome. You are always welcome to come back if you need help in the future.
Take care of yourself,
Jun 9, 2020 at 1:46 PM
