30 amp EEC and fuel pump fuse keeps popping
88,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
BRANDONDBENTON87
  • 14 POSTS
The 30 amp EEC and fuel pump fuse under the hood keeps popping and has flow of 12 volts with the fuse removed the other side shows 2 volts on the voltmeter. what should i check now and are there any wiring diagrams available?
Oct 21, 2020 at 8:27 AM
Good evening,
I attached a wiring diagram for you to view.
I would disconnect the inertia switch and see if the fuse still fails.
If it does, it could be the fuel pump. If it does not then it could be the ECM or wiring at the ECM.
The inertia switch is located on the LH side of trunk, below air suspension electronic control module.
Oct 21, 2020 at 9:23 AM
BRANDONDBENTON87
  • 14 POSTS
Okay, thank you. if that doesn't work are there any other wiring diagrams you can send me for the ECM? do you think it could be a short somewhere?
Oct 21, 2020 at 12:51 PM
One step at a time to try to narrow the area of failure.
Start with the inertia switch and let me know so we can proceed.
Oct 21, 2020 at 9:05 PM
BRANDONDBENTON87
  • 14 POSTS
Okay, thank you. i will lyk today after i try that.
Oct 21, 2020 at 10:10 PM
You are welcome.
Keep me updated.
Always glad to help.
Oct 21, 2020 at 10:12 PM
BRANDONDBENTON87
  • 14 POSTS
It ran for like 30 seconds then the fuse popped when i revved it up i unplugged the inertia switch with the key out it blew the fuse right away there is a computer mounted above the radiator fan that vibrated and made a noise for a second any suggestions where to look next.
Oct 23, 2020 at 7:32 AM
Okay, then it is not the fuel pump.
Unplug the fan controller and see if the fuse still fails.
That is the piece on top of the radiator shroud.
1. Disconnect battery ground cable, then remove radiator sight shield.
2. Disconnect electrical connector, then remove integrated relay control assembly from radiator support.
3. Disconnect electrical fan connector, then separate connector located at top of fan shroud.
4. Remove male terminal connector clip from shroud mounting tab, then remove air bag crash sensor.
5. Remove fan shroud from radiator.
6. Lift cooling fan module to disengage from lower radiator clip and end tab.
7. Slide cooling fan module clear of radiator hose connector, then remove two engine wire harness clips from side of fan shroud. Lift module past radiator.
8. Reverse procedure to install. Torque shroud to radiator nuts and bolts to 36 inch lbs.
Oct 23, 2020 at 7:43 AM
BRANDONDBENTON87
  • 14 POSTS
Unplugged the fan controller tried to start it would not start but did not blow the fuse. plugged it back in started it and it blew the fuse instantly. could there be an issue with the wiring or is the fan controller the issue?
Oct 23, 2020 at 8:12 AM
The fuel pump relay is part of the module. That is why it would not start.
It is a very common failure.
Replace the module.
Oct 23, 2020 at 8:13 AM
BRANDONDBENTON87
  • 14 POSTS
Okay, thanks again. i will try that.
Oct 23, 2020 at 8:15 AM
BRANDONDBENTON87
  • 14 POSTS
Would you recommend a used or new one? and what is the technical name of the module?
Oct 23, 2020 at 8:18 AM
New only. You can get it at Rock Auto.
Oct 23, 2020 at 9:08 AM
BRANDONDBENTON87
  • 14 POSTS
Okay, what is the technical name?
Oct 23, 2020 at 10:12 AM
Cooling fan control module.
Can you give me the part number of the old one? I will see if I can find you one.
Oct 23, 2020 at 8:47 PM
This is the procedure:
Description
The EEC Module receives signals from the Engine Coolant Temperature Sensor, Vehicle Speed Sensor, and Clutch Cycling Pressure Switch to determine if the Electric Cooling Fan should be activated. When conditions are met to activate the Electric Cooling Fan, the EEC Module will provide a signal to energize the EDF Relay (2.3L and 3.0L) or HEDF Relay (3.0L only) and operate the Cooling Fan.
Oct 23, 2020 at 8:50 PM
BRANDONDBENTON87
  • 14 POSTS
F1d7 aa is the part number i think.
Oct 23, 2020 at 11:49 PM
No, there are a lot more numbers.
Oct 24, 2020 at 12:33 AM
BRANDONDBENTON87
  • 14 POSTS
Okay, I will look and see.
Oct 24, 2020 at 1:28 AM
Okay, keep me updated.
Oct 24, 2020 at 1:40 AM
BRANDONDBENTON87
  • 14 POSTS
This is it is this the module you were referring too.
Oct 24, 2020 at 1:46 AM
BRANDONDBENTON87
  • 14 POSTS
Could you check and see if the one on O'reilys.com is the right one and let me know please?
Oct 24, 2020 at 1:47 AM
If you were sending a picture, nothing came through.
Please try again.
Oct 24, 2020 at 1:51 AM
BRANDONDBENTON87
  • 14 POSTS
F1DF-12B577-AA
Oct 24, 2020 at 2:19 AM
BRANDONDBENTON87
  • 14 POSTS
Could you let me know if the one on O'reilys.com is the right one ?
Oct 24, 2020 at 2:20 AM
I found a remanufactured one for you. You should call them and see if they have it.
https://www.autoecmstore.com/products/f1df12b577aa
There are lots of used ones but I never trust used electronic parts at all.
Oct 24, 2020 at 2:29 AM
