Electrical Issue
130,500 MILES • 3.5L • V6 • RWD • AUTOMATIC
JORDAN MCNUTT
Okay it started approximately a week ago i installed a led light bar to the front end of the vehicle, after about three days it started randomly not starting (even after driving awhile) i would get to where i needed to be and when i came back to the car it would not start, and now it got to the point that not even a jump start would work or using a battery charger. we had the alternator tested it is good, then we had the battery tested it was very bad, i bought another battery the correct battery and installed it this morning and still the same problem wont even try to start. if it would jump start for a while and the alternator is good and the new battery installed what else could it be?
Jul 27, 2016 at 6:28 AM
FREEMBA
  • 1,152 POSTS
Try disconnecting the light bar (put everything back as it was before). Now see if the problem goes away or persists. By the way, which wires [from the vehicle's wiring harness) did you connect the light bar to?
Jul 27, 2016 at 9:18 AM
JORDAN MCNUTT
the bar was removed yesterday and the problem persists, but thanks though.
Jul 27, 2016 at 11:41 AM
RIVERMIKERAT
  • 6,106 POSTS
Test starter draw. Make sure the cable to the starter is tight and there is no corrosion on it. With a test light, see if the smaller wire going to the starter gets power when the key is turned to the start position.
Jul 28, 2016 at 4:08 AM
